Fork seal removal.
I put this up on another thread, so I figured I might as well add it to the SG build... To be honest, I been doin' seals this way all my life, never gave it much thought...
I made these years ago, ,but I'll put some dimensions up here in a sec. Soon as I measure 'em.
They're cut from 1"X1"X1/8" mild angle. Cut 2 pieces about 1-1/4" long and drill a 5/16" hole through the center of 'em. Bolt 'em together with a 1/4" bolt and round 'em off with a disk sander, grinder...whatever, so they look like this......
With 'em still bolted together, weld a 3/8' nut to the bottom on one angle only. You now have a tool that makes removing fork seals a piece of cake.To use them, remove the snap ring and washer from the seal and take an Exacto knife and cut the rubber from the lower part of the seal. Two reasons for this.... one, ya gotta' make room for the angles and two.... the more rubber you remove, the less "bounce" you'll get when using this tool. The rubber absorbs the impact instead of directing it to the metal frame of the seal. So, the more rubber removed, the easier it is to pop the seal out. The rubber's pretty soft. It only takes about 30 sec. to cut it out...
Once the rubber is out of the way, insert the angle with the nut welded on and work it into the correct position. Work the other angle into place beside it and bolt it together with the 1/4" bolt....
Turn your lower upside down and insert a steel rod (3/8" or thereabouts) until you feel it settle into the 3/8' nut welded to the bottom of the angle...
If you have a soft jaw vise, clamp the top of the lower in it. If you don't have a soft jaw vise.... make one dammit... they're invaluable.
.... if you don't have a soft jaw vice, support the top (upside down) on a couple pieces of wood...
Let it rest on the dust seal shoulder.
Don't over-tighten!!! The lowers are cast aluminum. If you try hard enough, you can turn it into an oval shaped boat anchor. Just snug it up so it don't move around... 'nuf said. Take your BFH and give the steel rod a forceful smack... like you mean it. A couple of those and the seal will pop right out.
I been doin' it this way all my life and in all that time... I ain't never damaged a lower. Imagine my dismay when I popped out the left seal and saw this...
Yup.... some hack has been here before me.
