Tank Paint.... continued.
First off, I kept referring to the primer yesterday as epoxy. It's not, its a 2 part urethane primer sealer. Anyway.... just thought I'd throw out a few pointers on prepping for the topcoats. You'll remember that the tank was stripped to bare metal and then I bondo'd the dings I could see or feel. But bare metal isn't the best medium to detect defects. Primed the tank yesterday and 3 dings stood out like sore thumbs on the gloss primer. There were more.... The way to find them is to take some 400 paper and a block of wood... yeah, block sanding. You do it dry and just lightly hit it to knock off the high spots...
I'd already laid some glazing putty in the 3 dings I'd found yesterday.
As I sanded them down, other depressions appeared...
The red arrow is a depression unseen just above the obvious one. White arrow is another. On the black circle the 2 bare metal spots sanded on either side of the putty means that whole area is depressed slightly. The white circle is a shiny spot that the paper didn't touch. Yup another ding. More putty, then back to the block sanding....
Contrast that with the left side and the top. A light sanding and no shiny spots. Perfectly straight.
After all the putty is good, I'll reshoot them with a thick coat of primer, then repeat the light block sanding to see if I missed anything... then the whole tank gets wet sanded with 600... and it'll be ready for paint.
This folks.... is why a quality paint job ain't cheap.... many time consuming steps.
