Weekend update, Tuning phase
I started out by replacing my drooling right side petcock with a brand new one just for expediency sake.
The way it was leaking just wouldn't let me run my bike long enough to try and tune it. I plan to keep my two petcocks that I had previously rebuilt ( but still leak ) and really clean them up and polish up the castings and cut some new gaskets and keep them for spares.
I filled my tank and watched carefully, no leaks! Yay!
Then I adjusted the cam chain tension, it was not far out of adjustment.
Then I moved on to adjusting the valves. I was pleasantly surprised to find they were almost dead on. One exhaust valve was one, one thousands too loose.
Then I wanted to set the timing but the points were kind of fried, so I installed a new set that I had and gapped them and got them all set.
I then went to set my timing and I was having a hell of a time. The bike was missing and wouldn't idle well. The timing was jumping around, I kept changing my timing light pick up clamp back and forth from one spark plug wire to another, I felt the exhaust headers and the left side was hot but the right side was not. Then I could no longer get my timing light to pick up on the right side wire. WTH?
The wire pulled right out of the spark plug boot. So I cut the wire off about a quarter inch and cleaned up the cap with a wire brush on the Dremel and re assembled it.
When I re started the bike it fired right up and the timing settled down and I was able to set it . I checked the advance when I revved it up and it looked good.
The bike starts quickly and I can get the idle down to a low rpm, but if I twist the throttle, even a little the rpm takes off and climbs up to about 3,000 rpm and hangs there. And it's hard to get it to come down. The rpm's climb and fall of their own accord. I am wondering if my advance springs are shot. I can't figure it out.
It still has an intake air leak, I have not yet pulled the carbs to replace the mounts. I did however try covering different spots in my carb with plastic wrap to try and see if it would stop the leak. No Luck.
So I intend to change the carb mount on the right side where I hear the leak.
I also figured since my spark plug wires were messed up and my rpm's were so inconsistent , I might as well install my Pamco and see if it settles some of these issues.
So after all this I have pulled all of my stock ignition components ( except the advance unit).
So I am ready to install my Pamco and I have already run into a snag.
I CANT figure out how to mount the coil. It doesn't fit my stock coil mount. The kit I bought from Mikes includes a standoff mount kit, but it doesn't fit my frame mounts any way I can think of. Does anyone have any photos of their install? I may make a separate post in the garage because I am stuck until I figure this out.
Here is the coil I am trying to install. Anybody know how this mounts? The mounting holes on the new coils are wider than the mounts on the frame.
So please if you have any photos of how you mounted your coils please share.
If you have any thoughts on my rpm's hanging up please share.
I feel like I'm getting close. Today I had the bike running longer than ever before.
Also just an aside, I re tested the charging. When the bike is idling at 1000 to 1100 it is charging about 13.5 volts when the rpm go up just a little 1200 to 1500 it jumps up to 14.3 to 14.5
So that's where things stand right now.
Until next time
Bob
Edit: after posting this I did a forum search and found several posts regarding coil mounts.
