- Mount headlight properly
DONE!!!
- Find replacement line for clutch
DONE!!!
- finish off foot pegs
DONE!!
- mount indicators
FRONT ONES DONE!!
- mount coils
DONE!!!
- mount tacho and speedo
DONE!!
- mount Boyer ignition
DONE!!!
- add fake oil tank for housing electrics
DONE!!
- add key starter
DONE!!!
- add hi/lo light switch
DONE!!!
- add kill switch
DONE!!!
- add neutral light
DONE!!!
- add spark leads
DONE!!!
-Install Boyer power box
DONE!!!
-Install one way valve on breather
DONE!!!
-Bleed clutch
DONE!!!
- plug excess petcock holes
DONE!!!
- add petcock
DONE!!!
- install fuel line
DONE!!!
- add filter pods
DONE!!!
-clean and line gas tank
DONE!!!
- fabricate rear fender
DONE!!!
- mount rear fender
DONE!!!
- mount rear light
DONE!!!
- add horn
DONE!!!
- replace tyres
DONE!!!
- fab steering stop
DONE!!!
- make spacers for calipers/rotors
DONE!!!
- paint gas tank
DONE!!!
- add chain
DONE!!!
- Find replacement brake line for front brake
DONE!!!
- recon front caliper
DONE!!!
-Bleed brakes
DONE!!!
- sort out exhausts
DONE!!!
- mount rear brake switch
DONE!!!
- mount front fender
- paint fenders
- mount number plate
- wire entire bike
DONE THE ENGINE!!!
- add oil
DONE!!!
- add fuel
- run engine
- tune engine
- get MOT!!
Go her all wired up!! Well, just the engine. MY friend came over, had a look, took two hours to figure the wiring out and also routing, and BAM! It was done!!
I spent the evening cleaning it up and tucking everything nicely together. I also added OIL to the engine!! It is inevitable now!!
Pity the weather isn't playing along...
Rain all day tomorrow apparently so I will have to wait.
PICS!!!
And here is the wiring diagram. Please let meknow if you see anything that is odd or won't work!!
Also can't do anything tomorrow as my out-laws are coming out for the day, booooooooooo!!!
