Thanks 5twins! I appreciate it.
I think your rims will be fine as far as the structural integrity goes.
Here's hoping. I'm sure happy gggGary asked though. Now I will look really close and if unsure will get a second opinion.
I will clean up the inside as you've shown, great idea.
Worse comes to worse I'll get some new rims and stainless spokes and lace them to these hubs. Probably would be cheaper than buying used wheels in good shape.
Then I'd be left with a couple of shiny round picture frames for some garage art!
When life gives you lemons………..
Ya, those cad parts will probably corrode quickly now and end up as they were pretty fast. I haven't had a good look at the chain yet but I think I will replace it, the sprocket and the locking tabs anyways. There's not a lot of miles on this bike, but who knows how well that chain was maintained and it's probably the original now 40 years old.
Here is my finishing schedule. As you have mentioned in other threads, it is the Black Emery bar that is the biggest improvement and it probably makes sense to just quit there as maintaining them tends to continue to improve them as well.
That being said though, I could see improvement with each finer grade of compound. Noticeable up close, but likely not so much from a few feet away.
So we each need to decide how much time we want to invest.
Step 1 - Strip Clear Coat - I just used a gel paint stripper
Step 2 - Brass Wire Wheel - I tried cleaning the remaining pitting and corrosion up with a Nylox wheel, but it barely touched it so I resorted to a brass wire wheel in a cordless drill. The rear wheel wasn't as bad so I decided to try the Nylox again. It wasn’t as aggressive as the brass wire wheel and I saved some time cleaning up afterwards.
Step 3 - Hand sand with 180 grit emery cloth, 120 grit sandpaper, fine emery cloth. Used different grits dependant upon how aggressive I needed to be in different spots. This was the most time consuming step by far. Was able to go right to Step 4 - 240 grit on the rear.
Step 4 - Hand sand with 240 grit wet/dry - rinsed and soaked in water
Step 5 - Hand sand with 400 grit wet/dry - rinsed and soaked in water
Step 6 - Hand sand with 600 grit wet/dry - rinsed and soaked in water
Could have quit here and just finished up with some lubricated 0000 steel wool as this was already a huge improvement, but I wanted to see how far I could go.
Step 7 - Black Emery bar on a cloth wheel in a cordless drill. Started with Black Emery bar on a sisal wheel then switched to a cloth wheel to reduce scratching.
Step 8 - White Diamond bar on a cloth wheel in a cordless drill
Step 9 - Red Rouge bar on a cloth wheel in a cordless drill
Step 10- Green Polishing bar on a cloth wheel on outside rim edges only in a cordless drill
Step 11 - Final buff/polish with Autosol
Thanks for all the comments guys!
