You're not going to polish the chain, are you? ...he's going to polish the chain!
OK - but he’s only going to polish the OUTside of the links and leave the inside surfaces as-is.
......right Canuck - you’re not going to polish the INside surfaces of each link....
.....are you?
Oh dammit.
Clean it. Any other questions.C'mon, canuck! That scooter is pushing 35 years old, and you're "a little disappointed" because the exhaust has some scratches in it? Do you remember me asking about that glass case? What are you gonna do when you're riding it and get bug splat on it?
I'm sorry, canuck. I just can't stop bustin' on you... Because I'm sooooo jealous that "The Basketcase" will NEVER be that shiny! I'm not worthy!glass case on order
Did you try pulling the plug caps and plugging the meter directly into the HT wires?secondary gives me 29 Kohms. Assuming that is my issue. Spec is 11 kohms on the secondary.
Hmmm....Just tried that and you are correct. Resistance is now 11 on the secondary. Resistance across both boots is 8 Kohms or so. That explains the 29Kohms. Bad boots...or bad coil, or neither. Spec in book shows to measure it through the boots for 11 kohms??Did you try pulling the plug caps and plugging the meter directly into the HT wires?
No, interlock should kill starter as well as iggy. Try some contact cleaner at the TCI connector.
Also, TCI system gets finicky if volts drop below about 10-11v. Did you check for spark by just kicking it? Maybe batt. volts drop too much with elec start?
