1. Dismiss Notice
    Dismiss Notice
Removing Tack cable on case?
Discussion in 'The Garage' started by FatChance, Nov 10, 2019.
  1. FatChance
    FatChance XS650 Enthusiast
    44
    55
    18
    Wi
    I hope this is a easy fix, probably not. I'm trying to remove the tack cable from the right cover, the collar just spins. Is there a trick to this, if I pull the case can I sort this from the inside or do I need to remove the tack cable to remove the right cover?
  2. 5twins
    19,268
    10,514
    813
    The sleeve that the tach cable screws into shouldn't spin. It has a hole in it's side and should be "pinned" in place by the tip of the special retaining bolt (#5 below) .....
    [​IMG]
    [​IMG]
    So, either yours wasn't mounted correctly (end of special bolt not in sleeve hole), the end of the special bolt has worn or sheared off, or someone just stuck a normal bolt in there without the turned down tip it needs.
  3. FatChance
    44
    55
    18
    Wi
    My bad, I did back out the special bolt, should have said that. Here is a pic of what I have.
    Does this look like stock cable, not sure that it is? From the diagram it looks like I can take the cover off with the special nut removed and then figure it out?
    gggGary likes this.
  4. gggGary
    Carefully check out 5t's parts diagram. That tach drive typically leaks, the seal is shot, the threaded sleeve that holds it can be an SOB to get out, and the shaft has a groove worn in it from dirt grinding away in there. Fun stuff LOL.
    FatChance likes this.
  5. joebgd
    joebgd XS650 Addict
    299
    75
    28
    NY
    I only ever had to just screw it off. Did you try that b4 loosening the bolt? Maybe try to tighten the bolt back and then unscrew cable. It looks like the bolt goes in a certain spot of the shaft. You can probably feel when it's right.
    FatChance and gggGary like this.
  6. FatChance
    44
    55
    18
    Wi
    I took the cover off and it looks like the collar (part #4 above) is seized to the housing (part #1). With the bolt removed I can see in the hole while slowly spinning the housing and there is no hole or flat spot on the housing for the tip of the bolt to fit in or rest on. I can see the marks where the bolt was just tightened to the housing.
    How hard is it to find that housing, been searching a while with no luck? If it is available someplace I can be more aggressive with separating the collar from the housing.
  7. 5twins
    19,268
    10,514
    813
    Maybe your housing isn't seated into the cover at the proper depth and that's why you can't see the hole for the special bolt? No matter, the housing should pull right out of the cover once that special bolt is removed. Then you can get a look all over it for the bolt hole. Unfortunately, you can't buy the threaded part, housing, or the special bolt new anymore. Scrounging used ones may be your only option. Maybe gggGary can help you out with that. Or then of course, there's always eBay.
  8. gggGary
    I made a special tool just to get the threaded collar out of that sleeve. It's just kind of a screwdriver bit with a socket drive custom fit to the slot with a round collar to keep it centered. Could I find it again? mebbie.
  9. FatChance
    44
    55
    18
    Wi
    Mine apparently is not stock, I don't have those slots on the collar. Also could not find the hole however, like @5twins said, it might be there but the housing is not seated at the prober depth to see it. I will be looking at it again tomorrow, I also need to get the kick started shaft seated back in there. I knew not to let that happen and I did it anyway. Found a video how to reset that in another thread, I think I can get that.
    I thinking more and more I should get a play motor.
    gggGary likes this.
  10. gggGary
    Pretty high odds it's stock parts. (keep digging) LOL Some pics of the parts and one way to get that collar out. Even once the collar is out that seal is HAMMERED in there. tach bolt drill 008.JPG tach bolt drill 002.JPG tach bolt drill 005.JPG tach bolt drill 010.JPG tach bolt drill 015.JPG tach bolt drill 004.JPG
  11. 5twins
    19,268
    10,514
    813
    If the video you found for installing the kicker is the one where the guy grabs the splined shaft with pliers, don't do that, it's a terrible practice. You'll find all sorts of advice and videos on this particular install. Many involve zip ties attached to the return spring so you can pull it around and hook it onto the case. It's all bullshit, hack job fixes that needn't be done. Just follow the instructions given in the FACTORY shop manual and the shaft slips right in. I don't know why people struggle so much with this and why they come up with the crazy methods they do. None of it is necessary and you risk damaging the parts with some of them.
  12. FatChance
    44
    55
    18
    Wi
    Damn, now I have a home work assignment. They were helpful, the first I had already read.
    Looking on e-bay I found the parts out there, pricey but, that gave me the confidence to go at it with vice grips and channel locks. Everything came apart as it should. I couldn't find the hole for the bolt because it was full of metal fillings. Looks like that o-ring could be replaced.
    Thanks
      File size:
      197.3 KB
      13
    TwoManyXS1Bs and gggGary like this.
Share This Page
