1. Dismiss Notice
  2. Dismiss Notice
    Dismiss Notice
Starter Motor Gear Cover
Discussion in 'The Garage' started by Crackers61, Mar 15, 2019.
Tags:
  1. Crackers61
    Crackers61 Crackers61
    Hi Guys,
    Could someone please advise in regards to removing the gear cover plate, by removing the cover plate is any starter gears going to be impacted by removing the cover?
    I presently have an oil leak dripping from the under side of the cover plate.
    I note that there is a shaft on inside of the cover. I have a gasket and sealastic to stop the leak. I know i have to drain the engine oil prior to removing the cover.
    Many thanks in advance.
    Crackers
  2. Signal
    Signal XS650 Junkie Top Contributor
    Yes some of the gears may come out with the cover but you should be able to reinstate them without further dismantling the engine.
    Before you start are you sure the leak is coming from there.
    Common leaks in that area of the bike are the clutch push rod seal and the sprocket seal. If the sprocket is loose ( and they do back off even with the lock tab washer) they can leak.
    If your oil is new lie the bike on its side on a mattress and you wont have to drain it.
    TwoManyXS1Bs and lakeview like this.
  3. XSLeo
    I wouldn't use any gasket sealer on the gasket.
    Get the sealing surfaces clean and use a thin coat of anti-seize or grease. This will seal just as good and let you remove it next time. Some even use motor oil.
    gggGary likes this.
  4. Crackers61
    Hi Guys,
    Thanks for the advice. I'm pretty sure its leaking from the cover plate, had the bike running and placed a camera underneath the engine and filmed it. Only leaks when the engine is running.
    Would you believe its the only plate i didn't touch when rebuilding the engine!!!
    Crackers.
    gggGary likes this.
  5. TwoManyXS1Bs
    Clutch pushrod seal sees oil pressure when the engine is running...
  6. Crackers61
    Thanks,
    i'll check it out.
    Crackers.
  7. gggGary
    gggGary Stop that! Top Contributor XS650.com Supporter
    I've had several of those plates leak. The screw at the top that also holds the shift shaft guard is a typical problem area for that cover. I use some hylomar when assembling. check and clean the case threads for the screws. If any screws don't look great the next length up at the hardware store will usually work maybe with a washer if dry assembly shows it's a touch long.
Share This Page
