RT,Read the reply from Mikes xs regarding the Solid state Reg/Rec I had on there before installing
the VR-115 .It appears that they are stating that once the battery is fully charged the Voltage will then drop
to 13.5-14. Are they wrong?
It will only charge at 15 volts till the battery is fully charged then drop back down to 13.5-14 volts depending on who's voltmeter you're looking at.
Mikesxs
As per instructions,I ran a new ground wire from Reg/Rec to Frame.I also ran a ground from Reg/Rec to Black (ground wire) in Plug to Reg (as per instructions) The Reg/Rec is properly grounded to frame.Are there additional grounds that must be done. When the bike is warmed up and charging,it will show a voltage off 13.5 at idle BUT will increase to 15 Volts at
2500 rpm .The ground from the battery to frame is good also (New) On 2016-05-23, at 2:47 PM, Mikes XS wrote:
Warren, the voltage will go as high as 15 volts for a few minutes when you first start the bike, then should drop to 14.5 - 13.5.
Warren
if it does not drop the problem is the ground wire to the reg/rect. Check the ground from the reg/rect to the motor, engine and battery.
Product #24-2089 Solid State Regulator
Mikesxs
In your Installation Instructions with product it States that "New System should charge at 14.5-15 Volts at 2000 rpm (measured at battery terminals). Question: 15 Volts seems high,will this over charge my battery and possibly damage my Rotor. I am getting a Voltage off 15 and my Taillight (running light)keeps blowing,never had this problem with old original Reg/Rec which charged at 14.5.Please advise if 15 Volts is safe to run.
warren
