XS650D
XS650 Junkie
I may have found the issue. When i last tested my rotor i got over 5,thats back when i had installed mikes unit approx a month ago but after going thru 4 tail light bulbs ect i finally realized that unit just would not work correctly and got the recommended vr-115,but as mentioned it seems to be working correctly till bike gets warm so i decided to check ohms on Rotor again,was not expecting any change there but its now down to 3.4 ohms .I removed both brushes to test and tried with 2 different testers.I guess i need a new rotor.To test the Stator for resistance do i remove brushes and use ohms setting from either slip ring to the Alternator case,if so what should the reading be. Whats quality like on Mikes rotor and stator?
