I believe you are... the Rotor is the round heavy magnet that attaches to the crank with a single Nut and key way.... so it can only go on in one direction...... ( it cannot be 180 deg. out )
the stator is the wire coils around that big magnet that is where your TCI Trigger is attached to I believe.... ( i'm doing this from memory so if I'm not letter perfect bear that in mind please) you said the screws backout of the rotor ( there are no screws in the rotor that I know of) and they tore up the wires in the stator..... .... I took that to mean the screws in the stator windings backed out and caused the wires to be chewed up.....
Why would the tci magnet be in a different location on the new rotor than the old one ??
you must admit that it gives very little information to go on.... what year, is it original or what ?
being that it has TCI I Think it's between 1980 and 1984 ..... no points so we don't have to worry about that
but you said "Why would the TCI magnet be in a diferent location on the new Rotor" a diferent place than the Old one was....
Sense I cannot rationalise why you would replace the Rotor, when the stator windings were the things damaged I can only asume you ment the TCI magnet ( the trigger ) that is mounted on the Stator windings..... it simply shouldn't be , but I have no way of knowing if they changed designs or something.... so I thought about it and figured it may be that they just attached the TCI Magnet(the trigger)
in a diferent place.... it would have to be 180 degrees from the other position to work though .....
.... there is the TCI Trigger ( often refered to as the Pickup) and there is the Altenator brushes that ride on the copper rings on the Rotor
the TCI trigger is a rather large black oval looking box of plastic that sets on the 2 o'clock of the stator windings....
I don't think there is anything else down there but I could be wrong..... it's possable that you simply didn't have the stator in the proper Holes..... but it SHOULD only go on one way.... just like the Rotor....
perhaqps they sent you the wrong Stator ?
.... anyway , sense you repaired the old stator windings with "Heart surgury" hehehehhe ( I can apreaciate that!)
the point is probably mute anyway..... glad you got it going
Bob.......
