On many bikes, the centerstand was almost like an afterthought. Basically, it was placed where it fit best, not at the ideal balance point between the front and rear of the bike. Lift handles, if even provided, were the same. Many are way too far back to help as much as they could and should. The BMW R bikes from the '70s were an exception to this. They actually designed the stand to function as a work stand, and placed it accordingly. They also placed the lift handle almost directly above it which gave very good lift. The stand was placed practically at the balance point front to rear. Remove either wheel and the bike would rock back on the other one. In normal use, the bike sat gently on the rear wheel. But, if you lifted that wheel up off the ground, you could easily spin the bike around in a circle on the stand.
