Weak grounds on light cab blow bulbs. One blew a couple H4 headlight bulbs before I realized it was a weak ground.
On my 75 I have the battery ground hooked to the frame with a heavy cable, I run a second heavy ground cable down to a start mount bolt.
I don't know how I got the letters to slant but anyway, I have a junction block for all my grounds. I run grounds from everything that needs grounds to this junction block. I have a heavy wire, 10 ga. as I recall from this junction block the where the battery grounds bolts to the frame.
I always get the charging system wired up first. when I'm sure it's ok I them wire the ignition. This way I can kick start the bike and check the ignition for proper function. I also check the charging system for proper function. Once I know it runs and charges I then add the extras, Add a fuse run the wires to what ever I want to operate then to ground.
I use one 20 amp fuse for a main fuse, then mostly 10 amps for other things. One 10 amp to run most of the things like lights. head and tail on one fuse. turns, brakes on another, horn often gets one of it's own, loud horns draw a lot of current. I had one set need a 15 amp fuse. The ignition can run on a 7.5 amp fuse.
If you want more just add a fuse run the wires, easy to do,
