dps650rider
I haven't read this whole thread but since I have had some experience with this I thought I would chime in. My bike is an XS650SE which came stock with the 2 piece rod.
With the stock setup there was a slight adjustment change between cold and hot, I could get a happy medium adjustment that was OK but not optimal at both temperatures.
I tried a one piece steel rod for a while. The clutch feel improved but the change in adjustment was much worse, to keep it working correctly adjustment when hot or cold was a requirement.
I made a one piece rod out of 6061-T6 aluminum and used it for a couple seasons and several thousand miles. With this in place the adjustment change was basically non-existent, I could set it and never even think about adjusting it. Eventually wear became a problem with it but NOT on the ends possibly because I dimpled them a bit to spread out the load.
The wear occured where the pushrod rode in the bearing just under the seal. The way I noticed it was I was getting oil on my drive belt, the play was causing the seal to leak. So I ended up putting the 2 piece setup back in.
If a steel bushing could be added somehow where the pushrod rides on the bearing this problem could be solved.
