Rear Master Cylinder Rebuild
BowlingSS
XS650 Guru
XS650.com Supporter
Lawrenceville, GA
I have been looking at how to tear down a rear master cylinder apart? Found a number on the front master. I have the snap ring out but then how to get the clip out.
Thanks.
Bill
same as the front?
tap in at the lever to loosen, then compressed air at the banjo fitting?
The bore there is often corroded, gunked up pretty good. Some rolled up wet n dry sand paper with mineral spirits to clean up a bit before trying to force the piston out?
homer simpson episode 3 GIF
Shot a few across the shop myself!
