For Sale - 18' wheel/tire/drum
Jqb12
Boardman, Ohio
Yokohama World Tour 955, 4.00 - 18 tire w/spoked wheel and drum. Brake cable and bracket included. Excellent condition. $100 or BO.
Jeff
Call or text 330-507-9690.
I have to have a different fork set up to run this on my '75 right? Can't see how you have it set up on your ride...I was under the assumption that the fork has a spot for the bracket to attach to right?
1st of all, Dave Grohl is the man !!!
Here's what I know: The drum is off a Suzuki, so the bracket was fabricated to fit directly onto my forks. The bike is an 82 XS. So, you need to know if the 75 forks are the same as the 82. If so, you're in business - direct bolt on. Do some research, because Im not so sure the forks are the same. If I find anything out, I'll give you a holler.
Thanks, Jeff
Thanks, Jeff
Hi Jeff,
'75 forks are 34mm vs the '82's 35mm and the brake caliper lugs are different.
But the stock Yamaha wheels will swap between the different forks even if the brakes don't.
So whatever was done to fit the Suzi hub into the '82 fork will work for the '75.
The brake torque stay and cable bracket may well need some work done to fit the 34mm forks although it may be as simple as drilling some extra holes in them.
Pretty much what I was thinking...I have a 78 chopper with 35mm forks and it looks like they might be measuring different as far as a bracket goes...but I think I can make it work.
I'll be in touch soon Jeff...how do you take payment?
