For Sale - 1972 XS2 Parting Out
The 76 caliper mounts behind the fork leg. The 75 and earlier calipers mount in front of the fork leg. Otherwise almost identical, and the calipers can be interchanged.
Do you have the front brake hose and pipe from the master to the caliper(in good condition) Please let me know if you do and how much. thx don
I do have the steel pipe.
I always toss the old rubber hoses, but you can buy a reproduction here:
https://www.mikesxs.net/yamaha-xs65...-rubber-oem-306-25873-04-306-25873-05-00.html
You can also buy the steel hose there:
https://www.mikesxs.net/steel-brake-line-lower-xs650c-oem-533-25871-00.html
That's what I would do, but if you want to buy a good used original steel pipe from me, let me know.
I also have the little hose holders that clamp the hoses to the frame and forks.
I have bought the steel brake line from Mike. It's no go. Too short. The rubber lines are OK.
I believe this will work. That's Yamaha's part number.
http://www.nichecycle.com/ncs/categories/brakes/brake-lines-fittings/yamaha-brake-pipe.html
I bought the XS2 parts cache in this thread:
https://www.xs650.com/threads/sold-parting-out-72-xs650-to-build-a-chopper.64830/
Parting out complete bike minus frame, engine, and motor mounts.
All parts are better than what you usually see, and many are nice or very nice.
I paid a premium for this cache, so I'm not going to give these parts away, but I'll beat eBay prices for comparable quality.
SPECIAL -- I have too many XS2 front wheels and associated parts such as axle, rotor, spacer, speedo drive, and will make you a very good deal on these parts.
Pics are from the above link. Better pics on request.
View attachment 250536View attachment 250537View attachment 250538View attachment 250539View attachment 250540View attachment 250541View attachment 250542View attachment 250543View attachment 250544View attachment 250545View attachment 250546View attachment 250547View attachment 250548View attachment 250549View attachment 250551View attachment 250552View attachment 250553View attachment 250554View attachment 250555View attachment 250556View attachment 250557View attachment 250558
Hey there,
I'm interested in the air filter boxes. Just not sure if they will fit my 1971 xs1-b. They look the same, but I have heard that they are slightly different size. Please provide price and any info you may have on fit. Thanks, Roy
I only have 1972-1973 air boxes. You need 1970-1971 air boxes. They are slightly different.
With a couple of changes 1972 boxes will work. The biggest change is that you will need a 1972-73 battery box. I think you'd be better off using pods until you can find the 70-71 boxes. Don't trust eBay on this -- check the photos carefully. Somewhere on this forum the differences between the air boxes is explained.
Below is the air box differences. There are two 71 boxes on eBay. They sold already.
They now live at my house with new filters. I just put them on my bike about 30 minutes ago. Now I can get rid of the pods. I'm trying to figure out why I'm really low on power below 3,500 rpm.
I have lots of cases. Will sell a set cheap. Not sure if I have a 1972 set, but I might, and I think 1972-1983 are all the same. I'm sending you a PM.
I’d be interested in the forward foot pegs if you still have them. I’m looking for the metal peg, pin and spring.
Can you help with any of these?
Wanted XS650 Front End 35MM fork tubes
- Forks complete with lower legs
- Front Wheel Hub prefer drum brake if fork tubes are 35mm
If I need to go hydraulic to get 35 mm forks
- Caliper
- Master cylinder
- Rotor
- Caliper
- Master cylinder
- Rotor
Sending you a PM.........
