littlebill31
Smells of Raw Fuel
I finally got home and figured I'd mount my turn signals today. Followed the diagram as I should and hooked them like they should be. I did delete the canceling unit. I put a flasher from mikesxs on it as mine was gone. BUT, to test them I only hooked up the 2 front. The two rears I have are broken. When I turned the key on the signals worked, but would not turn off. The left would be on 'till I pushed the switch to the right, then the right would stay on. If I put the switch in the middle it didn't matter, one would be on. When I pushed the switch in, the fuse blows.
Any thoughts? Do I need to run all 4?
I will say that I only hooked up the left front and the right front, as in I didn't have the wires running to the rear signals without lights.
Thanks all
Thanks all
