Brown comes from ignition switch to kill switch. Red/white goes from kill switch to power ignition coils, there it also changes to brown and then goes to safety relay. Blue white comes from the ground side of starter solenoid coil to switch on decompressor lever where contacts put it to ground when lever is pulled.one of the things that confused me was the Start/Decompression switch and the kill switch being in the same bar switch and running the 3 wires......I had nothing to go on except this pic and the brown threw me when looking at the diagram and the safety relay has 2 brown wires
Oops... my bad.... solenoid to starter is blackHot from the batt, hot to the starter... both red.
All I was pointing out is that I made a mistake in my comment. Jus' thought I'd correct it, that's all.Is that what your referring to??
I just wanted to add some photos here that might be helpful. Detail shots of the tear down of my original left handlebar switch. Shows mechanical detail of the switch gear.
View attachment 135750 View attachment 135751 View attachment 135752 View attachment 135753 View attachment 135754 View attachment 135755 View attachment 135756 View attachment 135757 View attachment 135758 View attachment 135759 View attachment 135760 View attachment 135761 View attachment 135762 View attachment 135763 View attachment 135764 View attachment 135765 View attachment 135766 View attachment 135767
Wire colors coming from the Headlight On / Off and Hi / Low side of the switch
Green, Yellow, Blue, Red / Yellow
Wire colors coming from the turn signals and horn button side of switch,
Brown, Brown / White, Green, Pink
Aftermarket right handlebar kill switch, has factory color wires. Kill switch has red/white and brown wires, the black ground wire is just a jumper that goes to the starter lever, the starter lever has a blue / white wire running to it.
View attachment 135776 View attachment 135777
