doubletrouble
650Skull got it right!! point 2 to be exact. The Caliper bracket slipped right over the second rotor. I also found out the front axle bolt has a shoulder that will hold the speedo drive in place even it the fork is out just a hair.
Everything worked out great and thanks for all the input from everybody. If I was going to start over I probably would have taken the advice of grizld1 and just improved the single rotor setup. Too late now.
What a great website!!
DT
DT
It's hard enough to get some machines to have the forks run perfectly parrallel with each other. Example; anything old school British. Forks sliders need to move up and down perfectly parrallel. If you tweek the lower axle end of the slider in or out, your creating a wedge effect when the fork slider moves up, thereby creating a bind in the forks. Not only will your forks not work smoothly as they should, they will wear out quickly which will cause an addtional handling issue.
