Jimbo W
You may recall, I'm the goon who, not even drunk, drilled the left side carb on my '80 G, in the protrusion just above the throttle stop screw thinking it was the capped-off location of the mixture screw. It was weeks ago & I still can't believe my impetuous stupidity. I epoxied a tiny bb to seal the hole but guess what - it won't run on that side. Sure it isn't electrical (there's a spark), new plug cap, fully charged battery. Fuel runs out of the float bowl drain, mixture screws are both on 3 turns out (found them eventually) - they were much further out, maybe 5 turns. Have blasted carb cleaner through the intake but, while the right cyl is as strong as ever there is nothing from the left. Plug is not getting wet. So, what do you reckon I've done & can I save my carb? Blocked jet? What are the symptoms of a split carb diaphram?
Thanks in advance if anyone takes pity on me.
