Ajgamester
XS650 New Member
I bought and have been rebuilding a 81 es650 the problem now is I can get my idle quite right and I keep getting misfire randomly on one side. I have cleaned the carb w times and put in new plugs. The odd thing is if I unhook the plug wire on the side that backfires the engine runs the same minus the backfireing. If I unhook the one on the other side instead the engine instantly dies. It starts up real easy with the choke on but keeping the idle in a good range is hard after it was up sometimes when driving the rpm get stuck up high and I have to adjust the idle down until a later time. Any idle on what it could be should be awesome. Im about to try and get a new ignition coil for it and hope that's it is there anyway to check the coil.
