3Deuces
1981
New rings
Lapped valves
Rebuilt BS34's w/ 140 mains, 45 pilot, float height, check at 22mm, fuel screw 3 turns out. No holes in diaphragms, stock needles and seats in good shape. New o-rings on seat bodies (Thanks bdholsin!)
Short open pipes w/ lollipops in the end
Uni pods
Pamco and Hughs PMA, B7ES plugs.
Cam chain and valves adjusted. Have not tried to sync or dead cylinder because theres no way she would stay running on only the left.
Timing has not officially been set, but I have tried the center and left and right extremes of the adjustment with no improvement.
I've swapped plugs and coil leads side to side and the miss stays on the left. Carbs triple cleaned. The miss is bad at idle and seems to clear up as RPM increases. Pops out the exhaust and back fires through the carb. Right side sounds good.
Starts 3 kicks cold w/ choke first kick when warm.
Planning to do a compression test tonight just to rule out me F-ing anything up when I did the top end.
Any other ideas?
Thanks in advance
New rings
Lapped valves
Uni pods
Any other ideas?
Thanks in advance
