mfais
XS650 New Member
Hey y'all. First time posting but a long time reader. Here's the issue:
I stripped down and rebuilt a 76 XS650 in the past few weeks. Redid the wiring as well through a simplified wiring diagram that made use Bussmann fuse block. She was starting up good throughout the whole carb tuning and responded well to throttle etc.
Two nights ago I had a kickback which blew out smoke through the carbs. After that happened I had a huge drop in battery voltage and could not start the bike again. The tail light even went out. It took me from a solid 12.8v to the 5-6v range. (Not at the battery, at the fuse block. Battery seemed ok but did drop to 11-12v) I'm using a PS1208-L battery
To help diagnosis: I haven't welded on tabs to mount the reg/rec, fuse block, or the battery itself yet. There is also a lot of extra length of wire that will be removed once those are properly mounted. There is quite a variation in wire gage between the reg/rec, fuse block and battery. The fuse block is just floating around where the battery box used to be. I just checked the cam chain, valve clearance and timing. I'm stumped. What avenue should I go down to figure this out?
ALSO do you have to ground the stator with nylon screws on a 76 xs when you replace the reg and rec with a single solid state unit or is that just for TCI ignitions?
Thanks for the help in advance!
