pnedac
So I picked up an 83 XS that I am redoing (previously bobbed a 77) into a cafe. It was evident that the PO was trying to make a cool bike with $0.00 and it showed. Black primer on EVERYTHING and the bike did not run. Next day I got it started and took it for a little spin. Smooth through all gears and though rough, seemed not to be in too bad of shape. A lot of backfire. PO took the baffles out of the OEM pipes and failed to rejet. After I rejetted it it was much smoother, but I notice that you can turn the bike off and just a moment later it seems to "burp" (for lack of a better term). As if it has just one more turn left in it.
I have tuned up the motor to factory specs, run a compression test (good), cleaned the carbs and set the floats, and it still does it.
Now I have the top end apart doing a full blown rebuild and upgrading to a SPARX alternator and a Boyer Brandsen ignition with some custom exhaust. I think after the rebuild the problem should be solved, but can anyone help me identify what that is? It didn't seem to be too big a deal, but I know that it isn'y normal.
Any help is appreciated.
Pnedac
Pnedac
