Tonka
Im reading through all of the informational troublshooting threads as well as starting to go through all of the possible mantinience in my manual. Just wondering if anyone has had similiar issues and can steer me in a direction or narrow down my plan of attack. The motor is a 71, I believe its been rebuilt before but no idea if it was done right. The bike would not run when I got it, it would kick over but wouldent idle. I changed the points and condenser and no change. It has straight pipes and was way lean so I added some baffles to the pipes to give it some back presure and even out the jetting. I took it to a mechanic that rebuilt the carbs and jetted it correctly but kept having timing issues where it would be timed correctly, start and run fine and then as it ran the running condition would deteriorate and the the timing would be off. I got the bike back with plans to solve the problem myself. I put a pamco and pma in hoping that it was just an issue with the points but no luck. After the pamco install the bike started right up as It did for the mechanic and it ran fine for all of 10 minutes untill the running condition began to go south, I took it out for a ride and it was good at first through low and high rpm. It then started by stalling on idle and then began backfiring when revved, it was as if the jetting and timing was off as the engine warmed up, that was a week ago. So as of now, the bike has a fresh battery (wich has been tested), a fresh ignition, alternator carb rebuild and fresh fuel. The timing was close when it was running. Now I cant even get it to fire up. It occasionally will fire and turn right back off, any attempt to give it throttle and it imediatly turns off. The wiring has all been checked and since its in an amen savior frame with no turn sigs or horn there isnt much wiring to go wrong. Its getting fuel. Im going to start with checking the cam chain. I beleive that the issue is somthing internal that is either loose or just not reacting to the warmed up engine as it should. Please throw any and all ideas out at me. I dont mind tearing into this thing but Im learning as I go. Ive done carb work and general matinience but have never torn down a bike engine before.
