If you can find washers that thick at a hardware store they should work.
On torque, use the stock torque on all the bolts on the initail engine assembly. After 24 hours retorque to stock specs on all the bolts except the 8 big nuts. Use 30 fl/lbs on them. Once you have the engine installed, get it running and let it warm up good and shut it down. Let it cool off over night, retorque. Start the engine let it warm up good, if rideable ride it 50 miles. Change oil, let it cool off overnight, retorque. Ride it 100 miles, retorque.
Repeat this untill you can't add torque. Usually two or three retorques is all you need. Then check the torque once a year or so.
On the first 50 miles get the bike on an open stretch of road, get in 4th gear at around 35 mph, a firm roll onto 45 mph, not full throttle just a firm rollon, then let off and let the bike coast down to 35 mph using the engine to slow the bike. Repeat as much as you can in this first 50 miles. The rollon and coast down helps seat the rings in.
