Good questions/comments (and joke). My engine has very little wear on it and the cam chain looks like its new. (Most of the other components look the same.). The cam chain is the original one. (I'm embarrased to say I had to take the pistons out of the bike to get a tie wrap out.). I didn't break the chain when I pulled the cam; I just pulled the bearings off the ends and slipped it under the chain. I was under the impression the original chains were "endless" since they didn't have a rivet link in them.
Even if they do, I figured it would still be possible to slip it back on since it was there to begin with.
I've got the cam shaft bearings out to make it easier to slide the cam shaft back in under the chain. Using a wrench on the alternator, I can cycle the pistons up and down and the cam chain seems to rotate fine. Based on this, I assume it's not hung up in the guts of the engine. However, I'll give it another look tonight. I'll also try tightening down the top bolts down a bit more to see if I can compress the new gaskets. Looking at replacement cam chains at MikesXS, I may need to "gently" pry the chain back on.
Thanks again for the help!
