Hi
I replaced a badly worn out gas cap seal with a new one from MikesXS. The new one seems to be much bigger when installed compared to the old one, and I am unable to close the cap even with a lot of pressure. But maybe it needs to break in and compress over time?
The additional challenge I am having is that I cannot get the latch mechanism to work properly.
1) The key mechanism seems to have lost its "spring" - the action of being able to press the key in to turn and lock the cap. This loss of "springiness" is regardless of whether I have the unit assembled or not.
2) When i have the cap / key assembly together, I cannot turn the key to the right - and again no ability to press the lock mechanism in which may be the issue?
Before I took it apart, the springiness was there. So I probably messed something up.
Does anyone have an idea on what I'm doing wrong?
Thanks
Thanks
