jackstraw650
Stupid electrical question time: I have a '79 XS standard that has a damaged brake/throttle side switchable control. It needs replacing which, in itself, is no problem. Mike's XS stocks a controller that fits '76-'78 XS and has a headlight on/off switch. I was going to install an on/off switch during the build anyway........would using this controller work OK on my '79? I mean from the standpoint of causing wiring problems.....I know given enough time, etc you can make most anything work, but since my electrical ability can be contained in a peanut shell, I thought I would check. I believe motorcycles should have a headlight on/off switch, in spite of what the feds think.
Thanks,
JS
Thanks,
JS
