Tim of DO THE TON
XS650 Junkie
So I'm putting my engine together, and am putting the oil seals in.
Some background - I built a 750 rephased motor last winter, and ordered the seal kit from MikesXS. Based on recommendations from members, I ordered all the seals OEM from Yamaha as it was suggested they would be better quality.
From what I remember, I used a combination of the two sets. So I have many of the Yamaha OEM seals here to use on the engine I'm doing now.
Anyhow - bottom line is I needed to order the crank seal - behind the rotor.
Original part is labelled SD 25 40 9-L-1 It is 9mm thick and has a lip that mates with a groove on the engine cases. Part 93102-25121
Well this seems to have been superceded by a new part number, 93102-25061. This is a non-lipped 8mm thick seal. SD 25 40 8.
Any thoughts? Clearly it fits, given the same OD and ID dimensions, but there is no lip on the seal to mate with the cases and it's 1mm thinner.
