Ooh! some interest LOL.
My two previous Prei were gas only, no charging used. There
have been plug in Prius with limited range since about 2012.
I'm normally a buy "late model used" kind of guy but the 2023 Prius Prime has doubled the previous "20 mile battery only range" to 40 miles.
Since the battery is not "EV size" it only needs a healthy 110 volt wall outlet for the included charging cord. Charge time from fully depleted to 100% is about 9 hours. But there's a cheap work around. The charging cable (with a transistor based voltage converter) is relatively supply voltage insensitive RE the same cord with a different end is used in countries with 220 volt wall outlets
so all that's needed to "halve" the charging time is a 20 amp 220 supply circuit.
The rub is; then the stock cord end must be cut off to install a 20 amp 220 cord end OR you (I) cheat and make a wall outlet (or short "adapter cord") that accepts a 110 volt cord end but supplies 220 Volts. The problem with doing
that is obvious. Been there done that long ago. A near guarantee that someone will eventually destroy a 110 volt device by plugging it into the 220 no matter how much red paint and skull and cross bones images are applied.
I'm looking at buying a separate
220 volt charging cord to keep in the garage at home and leave the 110 cord in the car for charging while away use. But with fully automatic switch to gasoline power onboard, charging while away from home will seldom be a thing for us.
The good news is that I have already got several 20 amp 220 volt outlets and extension cords available around the ranch that I use for 220V shop equipment.
The only niggle is do I add: a convenient 20 amp 220 circuit or future proof and install a 50 amp outlet for
some later EV car purchase?
Full disclosure it's been wet since the car came home so it's sitting in the garage unused; I want to get it up on ramps and spray every nook and cranny and the entire bottom with
Blaster Surface Shield @650Skull , lanolin! ;^) That'll happen today.
Will also start nosing around some sort of solar installation.
