vernk
bought the 79 special 2 years ago. got it to run then killed it, bought it, took it home and tore into it. finally got it running a few weeks ago. rode it 5-10 feet to check basics last weekend. this weekend idled it for a good while. then ran her around the neighbor hood.
so...
right side carb blows black smoke when throttled
left side carb blows white smoke when throttled
bogs when throttled on idle.
when riding bogs down suuuuppper bad on throttle. if steady throttle rides but pops and stumbles. when i got back started back firing on right mainly, a little on left. and a tiny bit through right carb. played w/ mixture screws, no change.
threw in almost a gallon before and after was significantly lower on the eyeball and tank hand lift gauge o meter.
i have pamco ignition and dual coil, new plugs n wires from mikesxs kit, straight pipes, bs38 carbs will do pods or homemade stacks n pods. right now open.
i'll be removing carbs again, i'll work on a thorough clean and rejet. what jets shall i go for ladies n gents? I forgot what you told me daddyGcycles!
i gotta get my hands on a timing light. how does one time with the pamco, or do i not need to? i don't have the e-advancer...could that be an issue too?
never seen white smoke on an engine w/o antifreeze. is it super hot? what am i missing.
oh where's the best place to get a deal on the oil filters?
can't pull the plugs to read yet cause she still hot. was difficult to idle after the ride. and kept spitting fire so i shut her down in fear that i'd set her a-lite
tia
v
so...
tia
v
