Hi,
It was a landmark moment and personal victory for me today - my first XS650 project actually started. I've been working on this one for 3+ years now, and I don't think the bike has run for more than a decade. However, since I committed the cardinal sin of changing the ignition, charging system, and rebuilding the carbs and top end all at the same time, I am going to be chasing things for a while. But it started, so I am pretty happy. I'm looking for a little input and help from you guys and where to go next - it runs, but will accept no throttle input without dying.
What I got:
76 XS
New cam chain, guide and tensioner
Stock head, no porting work
Stock cam, valves and springs
New pistons and rings, first oversize
HHB PMA - although I am running straight off a battery as per PAMCO Pete's advice when tuning as I am eventually going to run battery-less/kick only with a capacitor
PAMCO ignition in middle advance position as per Pete
Stock BS38 Carbs, rebuilt with good diaphragms and 135 mains 30 pilots about 2 turns out on the idle screws
Running stock headers only for the time being, no mufflers
What's happening:
1st start-up: Choke ON; Starts on first or second kick. Once running, idles ok but is clearly only firing on left cylinder. Exhaust is strong out of the left pipe, just pushing air on the right. Right cylinder is cool to the touch and when shut down and plugs pulled, the right plug is wet and stinky. I am able to give the throttle a 1/8-1/4 twist and the left side responds fine, but right remains limp. It idles on its own pretty ok.
2nd/3rd Start-up: Choke ON and everything happens as described previously, but when I turn the choke off as it idles, the right side cylinder fires up and both sides are running as they should - right side heats up and exhausts are similar. However, it will accept no throttle input without dying/stalling. When this happens and I re-start without the choke on, it fires up but will not accept any throttle.
Other than what is described above, I have not yet hit it with a timing light or adjusted anything with the ignition.
So, any ideas on the dead cylinder and throttle issue when choke is off?
Thanks.
What I got:
76 XS
What's happening:
Thanks.
