flywheel question
banshee. The honda rotor is too big for the case. Punkskalar might know of some others that will fit, but everyone agrees to use the Banshee. all years of the banshee rotor work!
ok i have another question?i see you recomend pamco pete,s ignition for the banshee swap but i already have a boyer ignition. i can still use the boyer with no problems right i definately dont want to go back to points "they suck" i even put a electronic ignition in 1929 model a pick up because i hate points especially those.
From what I have read the Boyer will work ok if you run a battery with your PM alternator.
