onimoto
Hello fellow riders,
I am in the final stages of a bobber hardtail build and I will say that this has been an experience. I've never worked on a bike to this level and need some help. I have replaced the clutch, ignition, PMA and carbs. I made sure that the kickstarter is installed properly (after several attempts).
Problem: Bike starts with electric starter, won't start from kickstarter
Question: What troubleshooting can I do to get this working? I have a capacitor to use, but the only way that I can start the bike now is using a battery and the electric starter. Even with the battery connected, I can't get it to kickstart. Can I remove the clutch cover to ensure that the clutch is not engaged?
The bike is in Neutral. The clutch is not engaged (as far as I can tell). The bike starts up right away with electric start. Kickstarter turns engine over and stays engaged.
Thanks for your help. I am new to all of this and have learned quite a bit for these forums.
