Front foot pegs - looking for replacement suggestions
peterg
Toronto, Ontario, Canada
I’m looking for new foot pegs for my 1980 Special. The rubbers I got from XS650direct 3 years ago have all but disintegrated. Are there any other suppliers that provide better replacement rubber or any pegs from other bikes that would fit my bike?
Originals are best, even used ones. You can still buy them from Yamaha but they're quite expensive. N.O.S. ones pop up on eBay from time to time for a better price. The Yamaha part # on these changed from 1J7-27413-01 to 4L0-27423-00-00. Search either (or both) of those numbers on eBay from time to time.
Patience required, but in time you can find descent or even very nice original take offs. Some guys who custom build have them set aside. Bent, worn, and rusty are easy to find but the challenge is to score nice ones.
Ive upgraded or hoarded over the last couple XS projects. A strategy which works on any parts.
Good luck !
-R
The mounting grommets are also still available but very expensive. Again, the repops are bad. Well worth scrounging good originals for these too.
When either removing or installing the rubber grommets it is very tempting to oil or grease them. I would encourage using soapy water again in this situation. The water evaporates leaving the grommets better stuck in position. More rigidity and less slipping in the end is a much firmer feel.
-R
Thanks gents. I should have been clearer. I’m just looking to replace the foot rest with a new part not the whole assembly. Thinking maybe another model’s foot rest is a direct replacement or an after market foot rest made for an XS650.
Just a guess that several street bikes from the era should interchange.
https://www.ebay.com/itm/1976-76-YA...916790?hash=item215aa88eb6:g:v7MAAOSwlw1dre11
Yup here's a list
This Yamaha 3CK-27451-00-00 FOOTREST fits the following models and components:
Yamaha Motorcycle 1977 XS650D STAND - FOOTREST - BRAKE PEDAL XS650D - E - E00650
Yamaha Motorcycle 1976 XS360C STAND - FOOTREST BRAKE-PEDAL
Yamaha Motorcycle 1977 XS360_2D STAND - FOOTREST BRAKE-PEDAL
Yamaha Motorcycle 1977 XS360D STAND - FOOTREST BRAKE-PEDAL
Yamaha Motorcycle 1979 XS650_2F STAND - FOOTREST BRAKE-PEDAL
Yamaha Motorcycle 1979 XS400_2F STAND - FOOTREST BRAKE-PEDAL
Yamaha Motorcycle 1978 XS400-2E STAND - FOOTREST BRAKE-PEDAL
Yamaha Motorcycle 1977 XS650D STAND FOOTREST BRAKE PEDAL XS650D E E006501- F
Yamaha Motorcycle 1981 SR500H Stand/footrest
Yamaha Motorcycle 1981 XS650H Stand/footrest
Yamaha Motorcycle 1980 XS650SG Stand/footrest
Yamaha Motorcycle 1980 SR500G Stand/footrest
Yamaha Motorcycle 1980 XS400G Stand/footrest
Yamaha Motorcycle 1979 XS650SF Stand/footrest
Yamaha Motorcycle 1983 RX50K Stand/footrest
Yamaha Motorcycle 1982 XS650SJ Stand/footrest
Yamaha Motorcycle 1982 XS400RJ Stand/footrest
Yamaha Motorcycle 1982 XS400J Stand/footrest
Yamaha Motorcycle 1984 RX50L Stand/footrest
Yamaha Motorcycle 1977 XS400D Stand/footrest
Yamaha Motorcycle 1983 XS400K Stand/footrest
Yamaha Motorcycle 1979 RD400F Stand/footrest
Yamaha Motorcycle 1978 XS650SE-11 Stand/footrest
Yamaha Motorcycle 1978 XS1100E Stand/footrest
Yamaha Motorcycle 1979 XS400F Stand/footrest
Yamaha Motorcycle 1981 XJ550RH Stand/footrest
Yamaha Motorcycle 1980 XS650G Stand/footrest
Yamaha Motorcycle 1981 XS400SH Stand/footrest
Yamaha Motorcycle 1981 XS650SH Stand/footrest
Yamaha Motorcycle 1981 XS400 - XS400H Stand/footrest
Yamaha Motorcycle 1982 XS400SJ Stand/footrest
Yamaha Motorcycle 1979 SR500F Stand/footrest
Yamaha Motorcycle 1978 XS400E Stand/footrest
Yamaha Motorcycle 1978 XS650SE Stand/footrest
Yamaha Motorcycle 1980 XS400SG Stand/footrest
Yamaha Motorcycle 1983 XS400RK Stand/footrest
Yamaha Motorcycle 1978 SR500E Stand/footrest
Yamaha Motorcycle 1979 XS1100F Stand/footrest
Yamaha Motorcycle 1983 XS650SK Stand/footrest
Keep in mind that if you're looking for a complete peg (metal and rubber cover), they are right- and left-handed. Also, the pivot pin is a rivet install so would need to be drilled or pressed out then replaced with a bolt or re-riveted. Look for rubbers with the metal plate in the bottom .....
