Hoperator
book stains on motor oil
Year: 81
Carbs: bs34
Air filter: Pods
Exhaust: open header
Main Jet: 145
Pilot: 47.5
Float height: 22mm
mix screws: 3 turns out
carbs synced with manometer
cleaned again, again, and again.
cam chain set
valves set
timing set
Still running lean as evidenced through spark plugs being colgate white, popping from exhaust and hanging rpms. Also, when I turn the choke on, the hanging rpms condition is made even worse. Any clues? Would running a #50 pilot be unheard of? help?
Carbs: bs34
Air filter: Pods
Main Jet: 145
Pilot: 47.5
Float height: 22mm
cam chain set
valves set
timing set
