FLEA
XS650 Guru
after having trouble with breaking clutch springs , had the 8 plate clutch and at the time high ratio gears (all new) , found and bought a helco spec high performance set of clutch springs , these are 3 springs and 3 blocks instead of the normal 6 springs , haven't fitted them yet as they are still in the mail from England , before I fit them has anybody used them before , any probs etc ,when put the high ratio in i replaced the springs with new normal h/duty springs and broke 2 very quickly ,after replacing the broken springs and removing the h/ratio gears no probs , was thinking of putting the h/r gears back in while putting these new springs in BUT never seen this 3 springs and 3 blocks set up before , this is for road use only so any info would be great
