XS650_Bobber
Working in my project
Hi guys, I am just launching a new electronic device, it is not new in the market, I just make it better, I called ¨ i watch your back ¨ is a electronic device that make flash stop Leds, build thinking about the safety of motorcyclists, just a month ago a person close to me was killied by a truck hit him from behind, the driver left the scene, and other friend was killed the last year, so, I build this flasher, what is new in this device? this flash without press the stop to warning the drivers, and had two parking light levels...
I hope that this device save lives, I am trying with this that you never hear; Sorry, I dont see you...
Descriptions;
Measurements: 6,5cm X 4,7cm X 2,1cm
This unit is 100% solid-state and completely waterproof and comes with a 1 year warranty.
Only for 12 volts Leds
Input surge protection
Reverse polarity protection
Output protection
5 pattern selection
Encapsulated Electronics
Do not drill any holes in the unit
Input Voltage 12Vdc (14.4 nominal).
Input Current Up to 6 amp
Use a Fuse depending on the consumption of the LEDs (automotive type) No inclued
Can drive 6 amperes in the output
This unit must be connect to ACC, 12volts when the motorbike is ON
Two tail lights levels, must connect the first one to use the second one. 12volts
Brake signal input 12volts
5 Patterns
1º Plain, standar without flashing.
2º No flash without press the brake, when press the brake flash 4 times then steady on.
3º No flash without press the brake, when press the brake flash 4 times then steady on for 5 seconds and then flash again 4 times and so on.
4º Flash without press the brake each 5 seconds 4 times, when press the brake flash 4 times then steady on for 5 seconds and then flash again 4 times and so on.
5º Flash without press the brake each 1 second 4 times, when press the brake flash 4 times then steady on for 1 second and then flash again 4 times and so on.
Connect the momentary mode switch to the small wires in the flasher to change patterns.
The problem of sell my projects worlwide is the high shipping cost of were I am from, so, if I shipp without tracking number can take a little more time to arrive and the price is low, so, I can sell each stop warning in 23$ without tracking number and 30$ with tracking number
In stock ready to shipp, 30$ shipped via EMS with tracking number
Just paypal kalill_2001 (@) yahoo.com
Descriptions;
Output protection
5 pattern selection
5 Patterns
