cmyoch
XS650 Junkie
The minor electrical issues I've had since last fall have been easily fixed due to my peers on this forum. I'm hoping you guys can help again because this one has me totally baffled.
I made it about a mile down the road today when I happened to look down and see both my red tail light indicator light and white headlight indicator light glowing brightly. All of the sudden, I'm a sitting duck. My main fuse had blown. Luckily my wife was able to meet up with a new fuse and I managed to get it home. When I got home, my headlight fuse was blown as well. I traced all of my wiring and did not see anything grounded.
Originally, when I would turn on the key, my headlight failure light would light up until the bike started. Since I took off the headlight to trace wires, I turn on the key and my indicator light doesn't light up. In fact, it wont light up when the light is in either. Also, when I turn on the key and turn on the headlight switch, my tail light failure light glows. It turns off when I flip on the high beam. I have not changed around any wiring whatsoever. Could my regulator have caused the main fuse to blow causing another issue? I'll answer your questions to try to chase down the problem. I missed a good day of riding. Thank god I wasn't miles from home!
