jchrisk1
XS650 Junkie
Anyone ever mess with jeep brakes? I am having a hell of a time with mine. I have bled these brakes 5 times now with no luck. It's an 81 cj7 with power brakes.
I've adjusted the shoes on the rear, new master cylinder (bench bled), I depress the proportioning valve when bleeding, and the calipers are on the correct side with bleeders on top of the piston.
They will be hard when I finish bleeding them, but when I start the motor they are soft again until the shoes make contact then it is hard to stop. I am thinking I'm not getting any front brakes. Maybe the Proportioning valve is bad. I don't know and am at a loss. The only way that I know of to check the PV is to replace it.
If anyone has any experience with jeep brakes, please help.
Thanks,
Chris.
Thanks,
Chris.
