MrBean
Hello everyone, i recently purchased some brand new mikuni vm34 carbs from TC Bros for my 78' XS650. I installed them and tried to kick it a couple of times and it wouldn't start. I took the carbs apart, cleaned all the jets and passage ways with some carb cleaner spray. I also made sure the floats were at 24mm from the gasket seat. Petcock from fuel tank is flowing clean and i replaced my fuel lines and fuel filter and made sure the fuel was flowing smoothly before connecting it to the carbs. I reinstalled the carbs and tried kicking it again and still nothing. I sprayed some carb cleaner inside the carbs and kicked it again and it turned on but not for long. I kept repeating this process and the same thing happened everytime. It only turns on with the carb cleaner but does not stay on. I tried playing with the air and fuel mixture but still same problem. What can be the problem???
Carb specs
Needle Jet 159 P6
Needle 6F9
Pilot Jet 18.5
Main Jet 185
Carb specs
Needle Jet 159 P6
Needle 6F9
Pilot Jet 18.5
Main Jet 185
