Luckily, these carbs use very common and readily available Mikuni jet types. The mains and pilots .....
And for the air jet, a different type of main is used but in this case, it flows air instead of fuel .....
So, as I mentioned, the U.S. spec carbs are very lean. I wouldn't even bother getting the stock main or air jet. Instead I'd get one size larger main (135) and 2 sizes of air jets (130 & 132.5). If you plan on more mods like pod filters then you're going to need one size larger pilots (#45) and another size larger on the mains (137.5).
