Here are some more of the build photos in no particular order.
This is the flywheel after shaving off all the old cooling fins.
Petcock before-
After.
Magneto plate before cutting. I didn't need all the extra since I'm losing the fan and fan cover.
Internal, inverted brake levers and thumb throttle made from an old 3-speed shifter. The leather for the grips is normally used for relacing baseball gloves.
Making a dipstick tube from hardware store parts.
Removing/shaving the breather/drain-
This needs to be removed, so I cut it off-
Tap using a pedal tap we had at the shop-
Install pedal-
Cut off pedal
Mounting a rim as a sheave-
The rear drum hub. It's an old ATOM-
The engine when I bought it-
