XS650D
XS650 Junkie
tHX
No, that's not right. 6 diodes means 6 readings.... and the numbers are off. Put up a pic of your meter with it set to the diode scale.Tested my Rectifier. Set Electronic tester to Diode setting. (2000 with Diode symbol ) Rec plug disconnected.No Battery hook up also.
Red Lead to Red Wire all three whites are 1 or infinity
Red Lead to Black wire 6.2 6.0 6.3 on whites
Am I good? No chart in my manual to compare.
so far so good, you're halfway there, now;Tested my Rectifier. Set Electronic tester to Diode setting. (2000 with Diode symbol ) Rec plug disconnected.No Battery hook up also.
Yeah, 6K fwd biased and open the other way sound pretty reasonable. My concern is that he said he's using the diode function. Those aren't the numbers you'd expect for a voltage drop.Seem reasonable?
Used an analog meter for years to check diodes. All there was back then worked well.I just prefer seeing the voltage drop.
