Flyboy5584
Hi everyone.
I am a first time user of this forum. Thank you in advance for any help you may provide.
I am in the middle of my first restoration, a 1983 XS650 Heritage Special. The bike has not run in over 5 years. I have found most of the information for projects on the bike so for, however I am now having an electrical problem which I can not find any info on so for. The problem I am experiencing appears to be no power to the bike. I did the radio shack fuse block replacement I found from previous posts. The first time I powered up, I had a neutral light, the left turn signal worked, the right turn signal came on but did not blink and the tail light worked. No headlight in either low or high beam. I attempted one start and lost everything, no neutral light and no turn signals and no blown fuses. The battery is five years old but has never been on a bike. I tested the batt with a volt meter and it read 12 volts without a load. I am charging the battery and even tried a 50 amp momentary charge with the charger to see if I had any power with no results. I am thinking even though the battery has never been used, I took it out of it's original box, it may be too old at this point. I wanted to see if anyone confirmed my suspicion before I bought another one. Any other ideas would be appreciated.
Sorry for the length of the post, but I wanted to get all of the info out there.
Jerry
Jerry
