Hello again, I have had a look at past threads and found plenty of interesting information, but not specific to this problem;
when I stripped the engine I noticed the head gasket had blown in two place, but got on with aqua blasting the engine.
once cleaned up i noticed one of the head studs had eroded adjacent to one of the blown gasket poinuts, so I have removed the stud and sourced a replacement. Investigating the reason I have found one of the liners is not in the correct position and is 0.25 mm lower than the barrel/cylinder head surface. I found a good thread on the website about removing the liner, my possible courses of action are;
1/ reposition the liner and shim the liner up .25 mm with a home made shim of aluminium foil
2/ a local machine shop said they would skim the barrel top including the 2nd liner top to make all level.
3/ source a new set of barrels
4/ do nothing but fit a modern gasket in the hope it seals this time
5/ anything else the forum might suggest ?
I have attached a couple of photos as last time, any help greatly appreciated
