Charging system checks out fine, 14.2 volts at anything over idle.
If a replacement isn’t easy to find and economical , blocking it off seems like a viable option. I’ve owned several bikes without site glasses. If there’s no leaks, you shouldn’t have to keep checking the level.Good News/Bad News...
I have brakes, which is Good.
The check level window on the master cylinder is crazed and leaking which obviously is Ungood. Meditating on various ways to cure that. Silicone doesn't seem to have worked, but I didn't give it a lot of time to set up either. The Smart Thing would be a new master cylinder. The Redneck Thing would be to replace the plastic window or block it off.
Hmmmmmmm.![]()
and, may I add...........Stainless line, yes, but I don't think I'd do a kit unless it was leaking. The issue I've had with most Hondas I've ridden or worked on is they're just too civilized and refined. They have no "personality", lol. My buddy had a Silverwing and I rode it, and well ..... it did nothing for me, lol, too "blah".
Sub CX500 forum starting right here...I can't imagine needing the extras (assuming I don't break one putting it in...) so if someone else has a need, hit me up.
Well according to the Ebay posting, they fit about every Japanese bike with a sight glass ever made, so...Sub CX500 forum starting right here...![]()
JB Weld extreme heat a new product? Looks like it is "NOT" a two part epoxy type thing, water based!Sight glass kits came in the mail yesterday. Seems like good quality, consists of an o-ring, plastic lens and steel outer ring. Installed one and while it was a bit of a booger to get started, it fit well and seems to be working.
VHT gloss black and JB Weld Extreme Heat are here. I'll do the patches and get back to y'all on that, but need to wait for the primer before painting.
If it is air cure, blow some propane in the jar, cover it up and check in a week or two. That would prove the "Air Cure" theory.However, I was pleasantly surprised to find the mixed goop in the jar was still pliable. Apparently it air cures. I applied a bit more where the original patch had sunk/contracted a bit.
Pipes look great. Will be easy to touch up too!
Pipes look great. Will be easy to touch up to.
