Hi guys!
I'm running out of ideas. I honed cylinders last winter and also had bushings put in to the exhaust valve guides and had a valve done job. After rebuild the left cylinder smoked bad and there was fair amount oil in the left intake. So I tore it down again and put in new valve stem seals. No help. Smokes like hell and lots of oil in the left intake.
The seal is seated. Breather is open. Intake valve lash set at 0.15mm. Intake valve "side play" is in tolerance. Head gasket does not seem to leak (at least not outside).
Any ideas what is going on? Did I just f*ck up the stem seal installation or can the guide be somehow faulty? If the oil would be coming around piston rings then it should not end up in the intake. Right?
Any recommendations for quality stem seals?
Pekka
Pekka
